**SOLD**
Completely refurbished Southbend G56-OFEK single disc clutch with flywheel & hydraulic upgrade assembly for 2006-2010 Dodge Ram Cummins Diesel 5. 9L / 6. 7L G56 6 Speed. The clutch will easily hold up to 475hp and 900Ft/lb torque. The pedal pressure is a fair amount more than stock, and the engagement is extremely smooth (in my opinion, the engagement was as smooth or smoother than it was with the stock setup). This setup would be ideal for someone who tows frequently (especially if you haul heavy loads), but it is an all around phenomenal clutch for most any driver. I used it as a daily driver and pulled 10-15,000lbs a number of times with mild increases in hp settings, and I absolutely loved it! I've gotten into higher performance upgrades and I decided to replace my clutch setup with one that was rated for higher hp/torque levels. I now have one of Southbend's double disc setups.
If you have any questions/concerns please feel free to email me at -- email address removed -- or call me at (337) 354-9100 and I will gladly help in any way I can.
Application:
2006-2010 Dodge Ram Cummins Diesel 5. 9L / 6. 7L G56 6-Speed
Includes:
13" Flywheel
Pressure Plate
Clutch Disc
Throw-out Bearing
Pilot Bearing
Installation Alignment Tool
Hydraulic Clutch Assembly
Rating:
475hp & 900ft lbs.
Asking Price: $850. 00 + Shipping/Handling(if applicable) - I'm located in south Louisiana
Application:
Includes:
13" Flywheel
Pressure Plate
Clutch Disc
Throw-out Bearing
Pilot Bearing
Rating:
475hp & 900ft lbs.
