SPA backlighting too bright?? Solution...
Fuel Pressure
Major Problem with Weld Wheels
Just wait till the LEDs start flickering and then one goes out! That seems to have dimmed it a bit! ;)
I haven't called SPA yet to see if there is a fix, but if anyone has had part of the backlighting go out, is it fixable?
I'm guessing that these are not the second gen MarkII's? They have it where you can adjust it. If it is the first series, then I have heard of people putting window tinting on them to reduce the lighting.
Andrew
SPA
In the past we have always had to send the gauge back for that fix. They are under new management now which was long overdue.
you could replace the led yourself with one from radioshack, that is an option, these thing come apart easy, if its a mark I you are probably gonna have to do some fancy talking to patrick
adios B... ... ... .
Thanks,
I need to call Patrick anyway, the sensor that is in my transmission line (literally) came apart... . which explains my erroneous readings as of late.
