ABSOLUTELY NO PROBLEM with interference between my SPA gauges and my ("Turbo tuned") CB although, both are on a different circuit of my Painless Wiring Cirkit Boss. In addition, the antenna wire is routed in such a way that it is almost never near any other power wires, and where it does it intersects same at right angles.
Cliffman, I would use a better ground. Personally, when I used to install trick audio equipment in previous 4x4s I learned that a good, common grounding point eliminated a lot of potential future problems. On my '98. 5 Ram there is a good factory ground (stud with nut... the nut uses a 10mm wrench) on the driver side just above the plastic kick panel. I believe there was only one factory ground wire attached there when I first installing accessories.
Also, it's OK to coil up the excess coax cable IF you fasten it together in the middle like a skein (looks like a figure 8). Coiling the excess in a series of loops MAY generate interference. The Firestik website explains this in great detail.
