It started last night on my way home from work... and the second day after installing DD3's.
My SPA fuel pressure/oil temp guage has started acting up. At random, and fairly constant times, after the truck has been running for 20 minutes or more, the pressure will start to fluctuate, bouncing from like -32 psi up to 20 or so. I'll even occaisonally see the FL (fault) code appear.
This morning, I checked the sender and the electrical connector, expecting them to have worked loose. They were fine.
Drove to work today, and the same thing happened.
So... has my SPA sending unit developed a flakiness, or am I see a real fuel pressure problem, possibly caused by the addition of the DD3 injectors?
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
Rob
