2nd Gen Non-Engine/Transmission spacer for overload springs
2nd Gen Non-Engine/Transmission Headlight Buld Blew Up
Engine/Transmission (1998.5 - 2002) New clutch from dealership
Would like to place something between over load spring and overload bump block to help keep truck more level towing heavy weight, what are you useing?
Derek,
I have seen two different approaches to this.
First was to add a 1 - 1 1/2 inch piece of rubber to each of the frame brackets thus lower the contacts by this much.
The second option was they had a spring shop make them a taller spacer that just the overload sits on.
Don't go to high or they could hit under normal driving. But there is room to play there.
I have heard hockey pucks do a good job as spacers. Read a link where a guy drilled a hole in them and mounted them on the bracket, although I have not tried it myself.
Ron
Thanks for the ideas guys.
If there are anymore please post them I like to keep things simple, besides I'am cheap. :)
Ron
