2nd Gen Non-Engine/Transmission Spare Tire "Get er downer?"
Engine/Transmission (1998.5 - 2002) Thermostat ?
TGibbs
I lost all my jack tools (because I just had to have subs under the back seat!!) and I need to get my spare down to change it. Does anyone now a cheap place to get just the two tools I need to get the tire up and down? Oh and I am putting a 33" tire on the spare as that is what I am running on the rest of the tires, does anyone know if it will fit up there?
Thanks
Tristan
Only place for the stock tools will be Junk yard or the dealer...
A 33" tire will BARELY fit ... . TIGHTLY... . depending on the type of tread. If you have the stock exhaust, you might have to watch out for tire to exhaust clearance for heat.
Tire tool
Got my truck with no tools or jack. . Bought an 8ton hydraulic and made a spare tire drop tool from a piece of 1/2 round stock. A little work with a grinder to make a six sided head, then bend a 90 other end for crank handle. Not a big deal.
I had an older ffffurd that had the jack and tools under the hood. Possible to fab something up to hold stock stuff? I have 305/70/16s and the spare (same size) fit in the stock location - it's kind of close (1/2") to the 4" tail pipe though - I need to make a heat sheild
