Don't know if anyone else is using one of these, but I think I am really going to like it. It installs easily by tapping the tcc wire, od wire, vss wire, od switch wire and the cruise sense wire. It uses the cruise control buttons to set lock up speed and also the speed where the 3-4 shift occurs. You set the speed you want the converter to lock up and it will stay locked until a few mph below that speed. The same thing goes with the 3-4 shift. It will shift when you tell it to and stay in OD until slightly below the speed you set.
I haven't fully tested it yet, but I think it is going to work out really well. It sure is nice not to have the converter unlock every time you let off the accelerator.
