speaker size
How About A New Forum For "Cummins" Conversions
The Ultimate Truck
Does anyone know what size speakers these trucks have in them, front and rear? Have you replaced them with after market?What brand did you use?
Thanks MPb
92 W350,LE, 4x4, DRW ,4:10 LSD, auto,DTT converter, superior transmission shift kit, 16cm2, PW injectors, K&N, autometer pro comp gauges exhaust temp, boost ,trans temp, tach,pump adjustments black & silver, running boards, stainless wheel covers, 74 Road Runner, 69 Dart GTS factory 383 matching no. s
I replaced both front and rear when I added my 6 CD changer (Sony) I don't remember what size the front were but they were a standard size. The rear speakers were non standard and the only ones that worked were Pioneer. I went into the high end of the price range and am glad I did. The system sounds very nice. If you want info just let me know and I will do some digging to see if I can come up with prices and makes.
Happy Trails.
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
The door speakers are 6*9. Can't help you with the back speaker size though.
Doug
91. 5 D250 5 speed, 16cm2 housing, gauges (EGT, boost, tach), BD exhaust brake (w/ 60lb springs)
The front speakers are 6x9s and the rears are 4x10s. When you are replacing the front speakers, if possible its advisable to reinstall the shield. I have the Infinity Reference in the front and the Pioneer in the rear, they were the only 4x10s I could find at the time.
Replaced my door 6x9's with Pioneer Poly-cones to help with the moisture. Couldn't find good rear 4x10's so got boxes for another set of 6x9's. Good sound for the stock stereo, even drowns out the 2100 Rpm drone.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs. 237,500 miles (380,000 Kms) 7850 Hrs.
Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics
