special on the Volumizer??
Crusie Control, Speedometer, and Gauge cluster problem?
Foil in Engine??
I called to get a price on the Volumizer box, and they said they were having a special on it next week. Normal price is 590 and it is on special for 556. 00... .
I might consider it. Any current volumizer users that would like to give their input as to how they like it are welcomed :D:D
I paid 475. and it works great... got it here... http://www.rpmoutlet.com/ds994603ins.htm
curatchko....
Posting on the TDR message board just saved you a chunk of change on the Volumizer. That's more than enough to pay for next years membership due.
I can't tell you how many times I've saved money (amongst other things) by reading posts from various members.
It sure pays to be a member of TDR :D :D
Iwas just wondering if you guys useing these boxes could tell me if they had boost elbows, and what psi's are you getting. , thanks
No boost elbow with the Volumizer, in fact I don't believe our turbo will accept one. I was seeing 22 lbs. at full throttle before, volumizer, and 26 lbs. after. I haven't had this truck on a dyno, but the Volumizer really made this truck zoom!
So what's the scoop on the Volumizer vs. the Edge EZ box. There are a ton of these boxes on the market so how does the Volumizer stack up?
Originally posted by BacknBlack
Were you goys seeing alot of smoke with the two differnt settings(50,100)
I have not seen any smoke with the volumizer... but maybe you should ask the trucks behind mine! I have never had the Edge, but from what I read the edge will get you 65 HP and it is all fuel pressure boost. While the Volumizer is a combination of timing and fuel and has a toggle switch you mount in the cab with 3 settings (stock, 60 hp, 100hp)... the price is very competitive at $470. It is amazing that just with this box you can get this kind of power. My old 96' 12 valve would have needed some serious work to get over 400 hp.
