Speed control
ATF what do you recommend
215's That Stumble
I forgot, I tried checking for trouble codes using the ignition switch, none came up so I believe all speed signals are present.
Charlie
It sounds like you are on the right track. If a fuse is blown I'd think the green light would not be on. Is the linkage on?
We're here to help, don't give up on us!!
fox
