Speed sensor and ratio adapter
by-pass filter systems
'89 W350 Dually
Any help would be greatly appreciated. I haven't worked on one of these jewels in a while, but what I think I need is a speed sensor and a ratio adapter. I got a really clean 93 d350 with a 5 spd. The two wires that go to the sensor are just hanging there and the ratio adapter and speed sensor are gone. I have been unsuccessful in locating a VSS for either a 4x4 or a truck with a manual transmission. If I remember right I had a similar problem with my old w-350, but I finally found somewhere to get the VSS I just can't remember where. I have found somewhere to get a ratio adapter so a VSS is all I need.
If I can't find the right one, does anyone know the pulse count for the original sensor so I can make something else work?
I was able to get the correct VSS and ratio adapter from my local Dodge dealer. The price is on the spendy side... ... ..... but it fixed my overdrive issues (automatic). I would try to get a illustrated parts diagram with part numbers. Once you have the correct part #, you can track one down online or at a dealership. Good luck!
