I recently had the speed sensor (rear axle mounted) on my '99 go bad. After carefully wiping the area down and removing the old sensor, I found that the lower half was still in the axle housing. This plastic cased half would spin freely in the housing, so trying to grab it with a tap didn't work. Grabbing an edge with small needle nose pliers only broke off small pieces of plastic. :-laf Finally I tried grinding down a small diameter allen wrench until it fit into the plastic case. Then I heated it red hot and quickly stuck it down into the side of the plastic case lodged in the axle housing. With a little tug, out popped the broken half of the sensor case. Hope this saves frustration for someone else with a broken sensor case.
Ed K
Ed K
