Yeah its a little confussing! I have heard of someone making this work though! The GM unit has a 2 wire plug. One is low voltage and the other is the signal going back to the Speed Buffer sensor. Also, the speed buffer sensor has the ground. I have a bunch of different gears for the dodge unit that I will play with if I can get the signal to work but before I totally mess something up I would just like to know which wires are the 5volts, ground and signal to the ECM. (I think orange is to the ECM but could be wrong)
Ryan
