Details here: TDR Privileges
I am trying to hook up a navagation system . I need to tap into the speed sensor, I do not have 4 wheel abs / rear only. I have traced the rear diff. sensor wires they are wound together ,Does anyone know which one to tap into. Thanks.
Ok the wire is under the hood. Its white with a red stripe. You can get this wire going into the fuse box. It will be in a large cluster of wires but should be accessable on the rear of the harness towards the windshield. When I say rear I mean at the fuse box but on the back side of the harness. Be carefull not to cut the wire. I would recommend soldering it. Let me know I do this for a living.
