Speedi-sleeve and spicer nut conversion
Water control valve on heater hose.
Spicer Part #'s
:) Ok fellas, here's the scoop. Went to Portland today and stopped at the truck parts store. All part numbers are current and prices are as of 03-11-03. The stores are located in Oregon,Utah,Idaho,Alaska,Wyoming,and Washington. The web site is www.sixstates.com and I will give you the out of state watts 800 number for the portland store 1-800-547-7024 and shipping rates ups are about $3. 00 per zone east for 10lbs which would include everything. The companys full name is Six States Distributors Inc. with 17 locations. These part numbers are the ones on my 92 4x4 250 and work excellant.
CR Speedie Sleeve 99287 (2. 873-2. 879) @28. 20 Cr seal for the brake drum 28746 at 12. 85 or National #417158 or Dana # 39693. Spicer nut #35270 are 12. 00 ea. locktab washer #35269 are 1. 53 each. The OTC axle nut wrench PN 7158 and is a 2 1\2" and is 23. 14. Upgrade to 1 ton wheel cyl Wagner 28-35325 left and Wagner 28-35326 for the right. I know you guys know how to set the preload, however I will answer questions if you e-mail me. This will help you guys and believe me it is a much better system. Sorry for the long post. The national and dana wre given to me today, I used the CR seal. Tim
