The only tire size listed on my 98. 5 was 245/75/16. But on there scan tool they can go to tire sizes then there is a option called other and that lets you set your revs per mile. So if you know your revs per mile you can set it. I went to the dealer with what I thought was the revs per mile from a Tire manufactures website and my speedo was off even more with that number than at stock setting, then we looked in a manual they had with tire sizes and rev per mile numbers and it worked. They did not list my exact tire size but if you know the diameter of your tire it will work. Just use the closest match.
