I'll be going with taller tires shortly so I stopped by the local Dodge dealership to inquire about having the parameter in the PCM changed to give correct speedometer reading with the new tires. Minus any mass confusion, the tech writer called a mechanic over to answer my querry. In a '99 service manual is a page of tire sizes and parameters for the PCM. It's in the wheels and tires section of the book. He said the parameter is the "revolutions per mile". How much simpler could it be? So if you can calculate revs per mile, that's the parameter the tech needs to write into the PCM. He's going to do mine for the minimum diagnostic charge since there's no flat rate for the procedure. All parameters in any computer have range limits. Don't know what the range is for this parameter but it should allow for sizes we would be using with the exception of "Big Foot".
98 2500 CC 4X2 12v 5spd 4. 10, -silencer, AFC+20, Edelbrock IAS, VDO gauges
97 Dodge Stratus 150HP
92 Harley Fatboy, Dynojet fuel management, Supertrapp 2-1
