Details here: TDR Privileges
Last time they tryed it on my sons 99 it would only go as high as 265s. He had 315s on then and has since replace them with LT 295/75 16. They were limited in how big a tire they could go. But things could of changed by now.
There are a couple of companies that make little black boxes to fix this problem. However I don't know if they just fix the speedo or if they fix the speedo and send the new #'s to the Anti-lock breaks...
I have the Superlift Tru-speed. It works well and has 2 different settings. I believe it corrects the signal between the ABS and the ECM. I do have 4 wheel ABS and it works well.
According to the stealer: If you are going to a size tire that is sold by Dodge, they can reset it for you. That will cost you about 1hr labor at a dealer. Anything else, you will have to get an aftermarket widget to correct it for you. That will cost you around $200. :{
