So I notice my speedometer and odometer are not working the other day. In addition, the trans didn't shift past second and I didn't feel comfortable going over about 35 mph. I turned around and parked it. I already had an appointment at a local trans shop for fluid/filter change as I recently acquired the truck and not sure when last changed. I'd do it myself, if I didn't have to roll around on the ground. I called the trans shop guy and advised him of this development. He suggested "speed sensor" might be the culprit. So, this evening I get in the truck and everything seems to work fine. Speedo, odometer, trans seems to shift ok etc... I told the trans guy about this. He mentioned that in the event there is an issue with the gauge up behind the dash causing it to not work, it can also affect the transmission performance. . Is this true? Being a mechanical speedo, not sure how it not working could affect the transmission not shifting correctly. Thanks for taking the time to read all that! Roger
