Anyone else out ther have trouble with their speedometer-I have replaced the distance sensor twice in the last 80K. The speedometer starts reading erratic, fluttering from the actual speed to much higher, lower and back. This is like a gremlin in my truck. I have each of my batteries with a chassis ground as well as a block ground, so I doubt this is a gound problem, but it sure seems like a short of some type. I replaced the distance sensor adaptor with a sterwart warner setup a few years ago when I discovered my tire size was causing innacurate readings, but the OEM chrysler distance sensor hooks straight up to this at the transfer case. Anyone with a suggestion as to where to start looking would be greatly appreciated.
