I'm planning to add an auxiliary transmission to my truck and have done a little searching to learn how the speedometer gets speed information. Since the NV4500 speedometer would not send the right information all of the time with a variable ratio behind it, I was thinking of conditioning the output from the rear differential abs to be the speedometer input. I called a local transmission shop to ask what type of data the speedometer uses and was told that, unlike most manufacturers, Dodge used the NV4500 speedometer sensor output up to 20 mph and the rear differential abs signal above 20 mph. Can anyone confirm this?
