Speedometer/odometer problem
Would anyone be willing to.....
Getrag rebuild; speedo gear tooth count?
I am working on a 1990 2wd CTD with the Getrag 5 speed, the truck has almost 300K and is still serving as a trailer toter faithfully. However the odometer quit recently and then was followed by the speedo. I have looked everywhere and can't find a replacement of any kind. If anyone has one they would like to sell, trade, or otherwise make available I would like to know where else to look.
you can reach me @ -- email address removed -- or by phone @ 317 401 4843
Josh
www.dieselperformancesolutions.com
Distance Sensor
Often times, if you replace the Distance Sensor you can get the Odometer to function again. I just replaced one tonight that I ordered from the local Jeep Dealer ($73. 00) to no avail.
My Odometer still isn't functioning. This has been the fix in the past and a good place to start. The Drive Sensor is the upper most part that the wire connector plugs into. The Adapter is in the middle and the drive unit attaches to the Transfer Case (if you have 4x4) or Transmission.
Tim "KEENO" Keen :D
