I know this has been discussed before and I have read several posts on this but still have not figured why the speedometer reads 50 Mph when you are doing 70 mph and it does fluctuate a little.
I have replaced the sensor on the differential with no change in the situation. I also checked the new sensor for any metal filings after I had installed it.
Funny thing is if I disconnect the sensor on the rear differential the speedo is smooth as silk and the cruise will work. Of course the ABS and Brake light are on. Plug it back in and speedo starts acting up. At one point I disconnected rear sensor on diff and two plugs on the transmission and speedometer was still working smoothly.
Does anyone know where the second sensor is located for the speedometer?
Any help would be Greatly appreciated.
