Engine/Transmission (1994 - 1998) Speedometer working not!!!
Engine/Transmission (1998.5 - 2002) APPS Install
Engine/Transmission (1994 - 1998) Fuel shutdown relays
Hello. My speedometer had been fluctuating, and now nothing at all?? I would like to know if anyone has ideas??? I have yet to check anything... Thank you, Marc
You prolly chewed up the plastic gear that drives the speedo sensor. Mine is mounted on the transmission tailshaft, I believe yours is mounted on the xfer case. Remove it and count the teeth. Not really that expensive. Note what position the sensor is in before you remove it. If you install the new one and the sensor is not rotated correctly you will just eat it up too. If the gear is good then you need a new sensor. They changed plug styles so it will involve some wiring work. While you have it apart also look at how long the square shaft that goes into the gear is. Mine broke and only left about a quarter inch of square shaft. I became an expert at R&R until I got the new sensor and saw how long a good shaft is.
Did the odometer quit also? If not, you may have lost the speedo unit itself. If you lost everything, follow GAmes lead.
Hello Gary!
Well... ... Sprayed the plug with eletrical cleaner and bam... ... Working. . Think I should play the lottery... ... ... Thank you for the ideas... Marc
