Well I pulled the spinner apart last night thinking I was going to clean it and got a huge suprise. It was empty with no oil in it. Bottom line was that the check valve that is in the spinner stuck closed. I tore it down and when I tried to blow out the valve after removing the spring, it would not come out even with 125 psi of air. I had to drive it out with a drift. The cause is that when the thing was milled, it was not rounded but look like a piston with the top being in the shap of this _------_ . The little ridge around the end was designed to seat into a hole that it could seal. The edges were sharp and bound up.
So, I have run 16,000 on the same oil with only a regular filter change. I am not happy about this but I did find a weakness with the Spinner II that I am now warning you all about.
I have fixed the problem. I took the valve out and chucked it up in the drill press and rounded the end so it cannot stick. I also checked the opening pressure when installed. It was suppose to be 20 psi. But with the air set to 20 psi nothing. It would not open unitil I hit 40 psi on the gage. I shortened the spring. Took me 3 tries to get it where I wanted, but it now opens at 20 psi and does not bind.
I will pull a sample in the morning after I make a run. This will be interesting because the oil is about a dirty as it can get and now that I know the Spinner is working properly, we will see how fast it clean the oil of the soot.
I did not get any pictures last night as I was just focused on correcting the problem. I will work at getting some pictures of it disassembled to show the mods I made so the rest of you can benifit.
I believe in the technology of this unit. Just my luck that when they built this that they made the seating surfaces too tight and they stuck. But it is fixed.
More to come later.
