yellow jacket:
Although my truck is an antique Gen II and can't be directly compared to yours it does the same thing. I have to back my trailer up a short but steep driveway ramp from the street over the sidewalk and through a narrow backyard gate to park it behind my garage. The exercise usually requires a couple of attempts to get lined up and avoid the hazards and, unfortunately, heats the clutch. It always recovers after it cools and no permanent harm has showed up... . yet. I can't blame the truck. I intentionally ordered it with a 3. 54 differential to pull a 8k-9k# conventional travel trailer. Now I'm pulling a 14k# fifth wheel. I'm grossing 22,500# which is 2,500# heavier than the truck was rated for. As Jim said above, our reverse gear is pretty high for backing up hills in tight spots where you can't simply engage the clutch and let it roll along at idle. I suspect my clutch (this is the second one) will eventually fail but so far it has handled the weight for around 12,000 miles. Next time I'll order a 4. 10 gear. With 17" tires and wheels on Gen III trucks the 4. 10 is probably a little higher than in Gen II trucks.
Harvey
