spool Valve
A/C clutch
What's the latest ?
Have installed a Pac Brake and and a Two-lo kit.
Instructions for installing the Two-lo kit include a fitting to insert in the exhaust port of the valve. Attach a short length of hose to this fitting. Run hose inside cab of truck thru firewall with exhaust fitting installed in end of hose.
This method of instaliation is in the BD Two-lo kit instructions.
This may reduce service on the spool valve keeping it in a cleaner enviorement.
Have tried to remove the exhaust port from the valve that came with my Pac Brake and found it be be loc-tighted in. Any suggestions on how I may remove this exhaust port without breaking the fitting or damage to the valve?. I would like to route it inside the cab also.
Thanks Brian
