While coming back from LA yesterday, with my camper loaded and towing a car on my flatbed trailer, I noticed something unusual...
On my SPA fuel pressure guage, which usually shows 10-12 psi at cruise, and 6-8 while accelerating, it started bouncing around all over the place... positive pressure, negative pressure, fault (FL), etc. But ONLY when I was on the throttle using 1/2 or more throttle. If I let off or just set the cruise, it would, after a minute or so, settle down and show it's usual 10-12 psi. ONLY under a heavy throttle condition does it freak out.
That being the case, I don't think it's the SPA sender. Instead, I have to wonder if it could be indiciative of an impending lift pump failure? The truck still accelerated okay, though I suppose it did feel a little weak (hard to say, really). Fuel mileage was lower this trip than in the past, in the high 10's to low 11's (shoulda been 12+).
Fuel system is stock (no custom banjo bolts or fuel lines). The rest of my mods are in my sig.
Whaddaya think?
Rob
Whaddaya think?
Rob
