I have a 99 3500 cab-chassis with 178k miles. While going down road with either vent or air conditioner on the heat will kick in on it's own for 5-10 seconds and then turn off again, this will do this about once a mile. It does not seem to matter if there is a light or heavy load, fast speed or slow. A problem was first starting to apear when running the ac and there was not good control over temperature of the output, the heat was either all the way on or all the way off. I was suspecting a faulty vac pump but the local dealer said that the cruise control also works from vacum and if the vac pump was not working reliably he did not think that the cruise would work reliably either and the cruise works flaulesly. Any ideas?
Al
Al
