jkalchik said:. . . By an inline splice?
jkalchik
jkalchik said:Robert, how did you do the wiring to trigger the relays? By an inline splice?
jkalchik
Thomas said:No splices or cut wires are needed. Go to SUVlights and order a 7004 plug to fit the 7004 socket that is attached to either headlight. The trigger coils of your relays are wired into this new plug, allowing the in-dash headlight switch to control the relays. While you're at SUVlights you can order sockets and relays to complete your new harness. Be aware that D/C uses switched ground on the OEM headlights of model year 2000 and newer second generation Rams. I don't know about earlier years.
