2nd Gen Non-Engine/Transmission Sport headlights problem
2nd Gen Non-Engine/Transmission 2WD 3500 '97 - Confused on Caster!
Engine/Transmission (1998.5 - 2002) Fass Fuel Pressure ?
I bumped my sport model front-end into an invisible pole recently and had the damage fixed at a local body shop. Now the inside beams on my sport headlights are only on when I put on the brights. They’re working like the non-Sport truck lights now. I know for sure that before the inside and outside (all four beams) were shining on both dim and bright because I read about sport lights on <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:eek:ffice:smarttags" /><st1:stockticker>TDR</st1:stockticker> and being curious went out to check on mine just to see. The body shop must have got something wrong. But can anybody tell me what the possible fix could be or where I could start looking? I don’t know if maybe they changed a harness or what. I put a new 9004 in the inside with no change. The outside is a 9007 which works ok. Thanks Tim Brunett
