Hello,
I am doing the sport light conversion on my 97. I would like to install 2 diodes in the circuit I have planned but do not know what size/type of diode to use. As part of my wiring scheme, one particular relay will have two inputs (two separate wires) to pin 86. One input will be the “high beam on” and the other input will be the “low beam on”. I do not want current to back feed into the “low beam on” input when the “high beam on” input is energized and vice versa so I plan on installing a diode on each of these inputs. I am thinking about using a 1N4001 diode which is rated for 1 amp. Will this work? If not, please offer any suggestions.
Thanks,
Scott
Thanks,
Scott
