Spray in bedliner -gooseneck install
aisin question
When installing my goseneck, it says account for the thickness of the bedliner when measuring from the front of the bed.
It appears to be about 1/8 of an inch? I have the factory spray in liner. Any advise out there in Ram world?
If you are looking to determine where to punch the hole, crawl underneath and simply centerline the hole in the frame support.
What brand of GN hitch r u using
I would agree with this advice from what I have read. 4th gen 13 and newer are pretty darn easy.
2013 2500's don't have a cross member there. The 3500's for 2013 do. So do the 2500 & 3500 2014's. So not sure what you mean by frame support. It's a unhooked and has to hook to the side frame rails. 2013 2500's have the same frame as a 2012. The 2014 2500 is much easier
Ok, I have the exact same setup as you on my 2011 3500 gooseneck install mine is a B&W. Just measure from where they tell you. I did not allow for the bedlinen since it's so thin. My hole is perfectly centered. Good luck.
ahhh c I didn't know the 13 2500 had a different frame setup.. if its more like a 3rd gen I did a couple of those (B&W) I just measured and cut. Didn't really worry about the bedliner like others said, its pretty thin...
