Sprayliner cleaner?
TurboDieselLifeSaver
Price Check On Tires. What Do Ya Think?
Anyone out there know of a safe, effective spray on liner cleaner? Would like to keep it as new looking as possible. Someone said NOT to use things like Armour All, it will damage it. Is this true?
'95 2500,SLT. CC,4. 10,AT,limited slip,Roll-Top,Smoothie,Hellwig Springs,K@N,Bug Guard,Side Window vents,RV Power Side Mirrors,Blue&Gray.
Don Diego de la Vega
Rhino liners companies have a product to keep the shine on the coating.
2000 DODGE SLT,ULTRA-RUNNING BOARDS, AMERICAN TOOL BOX/FUEL TANK,AND REESE 20K HITCH,GTS BUG SHIELD,RHINO LINING . MEDIUM SIERRA BRONZE, QUAD 2500 LONG BED. 4:10 POSI-TRACTION REAR END W/AUTOMATIC. STAN'S 4" EXHAUST SYSTEM TURBO BACK, AND VOYAGER BRAKE CONTROLLER,PIRO/BOOST/AND TRANY GUAGES. ULTRA-BOARD MUD FLAPS. HEAVY DUTY TOWING AND ALL ACCESS. A POSI-TRACTION 4:10 REAR END. K&N AIR FILTER. MOPAR DEEP ALUNIUM TRANY PAN. KLEEN WHEELS, DD STAG 1 INJECTORS. CUSTOM BURLWOOD DASH KIT AND WINDOW SWITCH COVERS. 29' ALPENLITE 5TH WHEEL W/SLIDEOUT. 5" GENO'S CHROME EXHAUST TIP. STULL ALUMINIUM BILLET GRILLE. STAINLESS WHEEL OPENING TRIMS. POWER VENTED TRANY COOLER. Hellwig 3500 progressive overload springs.
I used simple green for a couple years, works great. Then I found Castrol Super Clean, I think it works better on road film or grease and oil in the bed. Got mine at Wal-mart. I use it on everything that is washable.
Thanks, guys! Looks like Simple Green is in the majority. Do you use it full-strength? Spray it on, then rinse, or scrub? The Castrol Super Clean sounds like it would be a good bet. I'm mainly concerned about 2 things: keeping the shine, and NOT HARMING the poly... material that makes up the liner.
Jim
Teacher. . All the above. . depends on the type of dirt/filth. . try dilution by label and go up if it wasn't strong enough... straight is a waste of product most of the time as diluted will do the same job. . your call
[This message has been edited by willyslover (edited 07-22-2000). ]
