Getting ready to install an SPS 62 that's been taunting me in my living room (where else?), and I have a few questions.
1. I have an auto transmission, and so I need to replace the down pipe. Since it has a clamp, similar to the muffler holding the down pipe to the rest of the system, is it as much of a challenge to remove the down pipe, or will I have to cut (much like a muffler replacement)? What are the tips and tricks for this?
2. I've read a lot of info on connecting the compressor to the intercooler pipe and the clearance issues involve with aftermarket air intakes. How is the clearance with the stock airbox?
3. I've read about having to prime the turbo, but they've all referenced disconnecting the TST and cranking the motor for a bit. I don't have a TST, but I have an Edge J/A. Can I disconnect the power to that and crank the truck? BTW, how long should I crank?
4. Do you use red Loctite on the turbo mounting hardware?
Anything else? Apparently, the turbos don't come with any installation info, and I've never installed a turbo before.
