Squeak in dash - new steering column
questions about grill covering
test for STOCK'er
A 6 month frustration has finally ended. After trying everything else,including all your suggestions guys, they finally replaced the steering column and admitted they had a lot of problems with their squeaking.
2001 Ram 3500 dually, 4:10, auto, SLT+,anti-spin,custom side paint, Custom pin striping,Advanced Thermal Products Sound Blanket Kit, Smittybar nerf step,Geno's stainless wheel well trim, tonneau cover, air dam, chrome monster tip, mud flaps/chrome tips,pyro-trans-boost gauges, Bosch 275 Injectors, Van Aaken, Kondalay TC & Valve Body.
Millfly
Inoticed on your signature you have a sound blanket,percentage wise how much would you say it reduced cab noise,i,m interested in getting one . Where & how much? Was the noise you had in your steering column consistent or intermitent ,cos ialso have an annoying itermittent noise. Thanks in advance. Ian
2001,2500 q-cab,auto 4x4,4. 10 anti-slip rearend. All options except leather seats. Line-x bed & tool box. Slide-in -removable rack,BFG 295,s ,Fender flares. Westin nerf bars,billet grill & fog inserts. Isspro gauges on their way,more to come.
Treeman,
It would take 30 to 45 minutes to start and they is was continuos with every bump in the road.
The sound blankets reduced the engine noise by 25%. There is quite a complete review I did under "Product Reviews - Members".
I got this squeeeck when ever I turn the wheel right or left and hit any little bump in the road. Doesnt squeeck at all driving straight and it drives me nuts. Is this what was happening to you?
Sky
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Exhaust, Bosch 275 Injectors, K&N... ... ... .
My 98 had that sqeak. While changing the fuel filter I accidently dumped fuel on the u-joint. The squeak stopped. After that I started giving it a little squirt of WD40 and it never came back. Now on my 01, I give it a little lube as part of my oil change service. No squeak.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Running Boards, Fog Lights, Real Backup Lights, Running Boards
No my squeek is coming from the inside of the truck.
I thought mine was inside the truck also. It was very noticeable on slight turns. It started as a slight occasional thing and got to the point where it was very irritating. I was banging on the column and dash and noticed that it would only do it when the truck was moving.
I've been there done that after 6 months of aggravation. I went to Carson Dodge and they used a spray lithium grease on the steering shaft in the engine bay right on the u-joint. Try it works... .
[This message has been edited by RankRam (edited 12-14-2000). ]
Really? hmmm never would have guessed, ill try it. If I didnt crank my stereo so much id probly would go crazy listening to that squeeck.
