2002 6-speed w/ a SB DD Clutch:
One minute the clutch worked fine. Stopped the truck. Next time starting it, the clutch squishes straight to the floor, like stepping on a plum, and the problem is only getting worse. I can barely get it into or out of gear. When I press down on it, there is a split second of pressure, and it instantly bleeds off, and the pedal squishes down, becoming ineffective (making it impossible to get in or out of gear). I was able to drive home by stomping the clutch down while simultaneously slamming it into gear before the pressure bleeds off at the same time (at which time the clutch catches and the truck either stalls or jerks forward).
I think it's the clutch fork actuator, but I'm not 100% sure. The fluid is full, and has not moved. It is not a problem that has gradually come on. One minute the clutch worked fine, the next, it's like this. Would the actuator just fail all of a sudden like that? Or is there something else in play that I should be looking at?
Thanks.
Thanks.
