Difference between a SRW and DRW
Be sure you know what you are buying and pull the cover. I bought what I thought was a DRW Dana 80 with disc brakes for my truck and ended up with a 2001 SRW disc brake rear. I know, I know the hub on the DRW is longer than the SRW. I had been looking for a long time and was excited. I measured the spring perch width and pulled the cover. I noticed that the hub length was different than my drum brake DRW axle, but I thought maybe it was different because it was a disc brake axle! I was over excited and thought I had done my research. I called Quad 4x4 and read them the tag number off of the new axle and they confirmed the bad news. The dismantler wouldn't take it back! So I dealt with it. I put longer wheel studs in the SRW hubs and I'm going to run 19. 5 dually wheels which will clear the brake calipers. The axle will be wider, but I'm going to run a flat bed so it won't be as noticeable. The wheel bearings are not as stout, but oh well.
Long story short, here is what I learned.
1. The SRW axle is wider hub face to hub face than a DRW axle. (I think it was 1 inch on each side)
2. The wheel bearings are different. They are larger on the DRW.
