No, the included instructions don't mention the grease. I emailed SSI and got a response. It was nice to have as it made slipping (prying) the bar into the mounting brackets quite a bit easier.
I had to resort to my farmer roots to convince the bar that it wanted to be in the frame side bracket. Put a 4 ton bottle jack up on blocks and pushed REAL hard on the back edge of the bar to get the holes to line up on the backside of the bar/bracket junction. Manipulating the steering wheel got the bolt in most of the way from the front but there was a slight twist in the bar that wouldn't allow the holes to line up on the back side.
And of course, even with the grease, a variety of pry bars were needed to line up and otherwise insert the bar into the axle end of the bar.
This install was done after last night's tie rod/drag link/steering damper replacement evolution. Basically got a new front end under the truck now.
Now it's off to the front end alignment shop. Hopefully there won't be any surprises like "You need new ball joints too. "
The truck seems to drive better. It seems quicker when I turn. Maybe there was that much slop in the front end. The original track bar was near death IMHO. The tie rods/ends seemed to have a lot of play as well, so I elected just to replace the whole shootin' match.
All MOOG parts, all have zerks.
