Stabilizer Bar?
diablo power puck
Hood Struts, a cheaper route!
I have KORE's sway bar drop blocks on and was curious if a stabilizer bar will fit? Has anyone ran into this or do I need to get longer end links?
Are you wondering if you can use the OEM sway bar by installing the KORE drop blocks? Or are you wondering what steering stabilizer will fit?
--Eric
It will fit just fine. You will need longer bolts. I removed the Kore spacer blocks when I replaced the end links with the Max kit they were longer and had to be cut down.
