Originally posted by ThomasLawrence
Well, two things: First, the EZ doesn't work with the 600. Secondly, even if it did, you don't have nearly enough air to run that combo. Even with a DD Jammer turbo cranking at 40psi, I only have enough air to run the TST on 5/5, and the EZ on 4. Beyond that, the power drops off (observed on dyno).
you guys are missing the point. First off I was the first one to run the EZ on a 600 on this board, and IT DOES MAKE POWER! level 4 is too much pressure for the 600's fuel rail(thats why I ran it on level 3). Second pressure makes fuel atomize better which makes it easier to burn givin the amount of oxygen in the cylinder. The added pressure can flow more fuel at a givin injection pulse length but with the fuel now being sprayed at a higher level of pressure its easier to burn. Also on my TST box theres a huge jump of power between 3/3 and 4/4, If my SOP feeling is less on 3/3 with the EZ connected than with the TST on 3/3 by itself, then how can that be explained? My TST box on my truck can make useable power till about 7/7 so if Im on 5/5 with the EZ on lvl 3 shoulnt it have more power? Read the above post by NOT_AGN he says he ran a 14. 6 TST with EZ and a 14. 88 TST only with stock turbo so heres proof that the turbo can do something with the stacking combo. NOT_AGN, As for the 35 psi and your fueling, talk to mark at TST and he can program your box to not cut back on fuel for more disired fuel and boost with proper wastegate settings.
