Details here: TDR Privileges
I was wondering if you can stack a chip or a programmer on the drag comp? What are the benifits and the downfalls to this? Would yall recomend it? Thanks
I am stacking a superchip programmer with my comp, not drag comp, and i dont know if it does all that much compared to the comp or not, but i need to dyno to see if it adds any power. Also im not sure if the superchip adds timing or not, hopefully someone else does, and maybe i shouldn't be running the two togethor, i dont really know. Hopefully somebody will chime in as to what a superchip acutally does.
Thanks for the update steve, more numbers coming up all reports with the catcher upgrade is most boxes are either being turned off or way down with the CaTCHER program.
I only have wimpy little mach 1. 5's so I have room to turn up my APB a little If I set it much more than about 1/3 it smokes a bit much though & gets toasty. Maybe I should set my waste gate up a little. It's limited to about 31psi now. If I had those big shower heads like you I probably would never turn the box on.
