Engine/Transmission (1998.5 - 2002) Stacking boxes
Engine/Transmission (1998.5 - 2002) Ats Arc Flow Mainfold Cracked
2nd Gen Non-Engine/Transmission Popping Noise from Bed of Truck
Get injectors to get alittle more more, Or alot of power depending on your setup. Also You Can stack boxes but not the ez. The comp would act like a ez if you left the pump wire off. You can have your ecm reprogramed to get some power then stack the comp to the ecm. Theres tons of ways you can go.
