Stacking the TST and EDGE EZ how too??
Where to put EGT probe??
Boost Gauge
My tst should arrive on Thurs or Fri. Oo. :D :-laf . I was wondering what level to put my ez on?? Which should be pluged in to the motor ez or tst??
Plug the TST into the engines map sensor first then the EZ follows right behind it.
Choose any level of your liking on the EZ.
The most aggressive is nicest though.
jwilliams3 Plug the TST into the engines map sensor first then the EZ follows right behind it.
Thanks jwilliams3 for the quick response I should recieve the tst tomorrow... Oo. Oo.
I ran the EZ on 1 and moved the TST around for a while. I liked it. Last week I moved the EZ up to 3 and tried the TST on several levels. MUCH smoother power curve and EGT's are quite a bit lower.
Cool thanks for the info... ;)
With the TST and Edge stacked. How much black smoke is there? I'm one of the few out there that could care less if my truck dumps black smoke or not. Either way I live in CA and have to be careful. My TST use to smoke quit a bit when I'd get on it. But since they reprogrammed it it's better. But by adding a pressure box on top, I'd think it would dump. Also, what type of temp drops am I looking at? I can smoke on 7/7 when I get on it. But it's not that super black soot coming out. It's more of a dark haze that comes out for a second or two. I don't want to have to be carefull everytime I get in the truck.
