Details here: TDR Privileges
Can i stack the XZT with an edge hot juice on my 06 when the edge is available? I am looking at doing that along with the bb turbo from edge looking to get around 500whp and still stay reliable. Thanks
the edge turbo is a good turbo but it will run hot after 450 hp--not a real hp producer---your better off with a sps62 it will last just as long and its rebuildable, plus it will make the power you want, with the hot edge you will be right in that ball park. you should not need to stack to get the power you want.
you first need to find out what box adds pressure and what box adds timing and duration---then you can stack, if one box does all three. you will want to stay away from it when stacking.
The quad box does a combination- timing and pressure- With the towing module like you have its mostly timing but it also adds some pressure I just don't know how much.....
