Stained trim cleaner?
vehicle ride
Bought Truck - Thanks for the Advice
B.G. Smith
Any one have any solutions to clean stained rubber/plastic trim on an RV? The one strip I am referring to is hard plastic I think and was originally off white in color but is now streaked with what looks like mildew. Thanks, bg
Try a little bit of brake clean in one area. The other thing that would be good to use is Take Off, Loews or Home Depot may have it. Take Off is one of those citrus cleaners that's good for all kinds of cleaning.
clean it up
After all is tried steel wool and pine-sol ,remove from trailer check for rusted screws paint or replace most are square drive if you do not have a driver make one by grinding a old philips ect ,to remove strip remove screw from ends and pull up and out ,takes plenty of work to do a compleat trailer but is cheaper then replacement. Hope this helps . Ron in Louisville KYOo.
