stallingI
Pacbrake blows down the air tank w/o working.
HELP! Two Bent Push Rods After Replacing Injectors
skorski
I left home and put on 6 or 7 hundred miles the 2005 was purring like a kitten. Fueled up, cruising at 65 for a couple hours. Pulled off the highway, got to the end of the exit ramp and it wanted to stall. Kept stumbling. Changed fuel filter, added injector cleaner, that helped somewhat. No problem at highway speed, only when accelerating or stopping. Any suggesting?
Any codes present? Hopefully the fuel conditioner will free up any possible mechanical issues such as a sticking FCA.
When mine started missing under load it was a clogged FF from a load of bad fuel. I had to change it two more times in the next couple of hundred miles before it was better.
I hope it's that easy for you.
Scott
