I know there are plenty of 2 micron filter threads, but I took a different approach and some here have PM'd me about what I did so here goes:
After I got the 06, I knew, like many here, I wanted better fuel filtration. The FASS on the 01 is great, but I thought I'd try to keep the stock filter, WIF and heater. So I looked high and low for a filter head that would satisfy my desires. I settled on a Stanadyne FM1000. It is rated at more flow and pressure than most other filters I looked at and was supposed to be 98% efficient nominal at 2 microns. This was all before Richard came out with his 2 micron system at GFS. Got the filter head at my local Cummins repair shop and it came with a 5 micron short (4 inch) filter. Here's where the trouble started.
Turns out, Stanadyne doesn't make a 2 micron filter for this head as their literature says (although they said they get a lot of request and may offer it in the future). Needless to say I was kinda torqued about this but, not to be deterred, I embarked on a long search for a suitable filter. I found that Donaldson offers the same filter head and they do have 2 micron filters, both the 4 inch and 8 inch. It is only 95% effecient though, but that's good enough for me. The filters where hard to find and I had to get 3, but it works.
See the photos for the install. The head is rather large but it fit fine. Used a piece of 4x6 inch angle aluminum that the machine shop had sitting around and some aluminum flat bar. It fit perfect where the APPS usually goes. I would like to use the larger 8 inch filter and I think it would fit without interfering with the CP3 but it would be close. If I could get one of those filters with the ability to return it, I may give it a try later. Raising the filter head higher would interfere with the dip stick, but that could be fixed if necessary.
The FM1000 has options for a heater and WIF. The WIF could be hooked to a dash LED it one wanted. I'm going to stick with the stock heater and WIF. Overall, I'm very satisfied, thus far, with the set up. In retrospect, I may have just used GFS filter setup since it's all packaged together and ready to go if that had been availble at the time. The other idea I had would be to replace the stock unit altogether with the FM1000 and the longer filter. Use the optional heater and WIF (which could probably be wired to the stock sensor harness) and one would have good filtration at any hp/ pressure/ flow this engine could ever need. If anyone is interested in part #s let me know.
