standard arp 2000 studs arp part # 247-4202
Troubleshooting a Problem, Then a Code
Fuel in water sensor
Kent Kuykendall
are standard arp 2000 studs arp part # 247-4202 strong enouph to prevent future head gasket problems? i am runing smarty jr towing on standard 0 setting. and i am deleted
Kent
They should be fine... we usually torque them to a higher setting which arp wont comment on but it works,make sure you get the proper lube for the nuts and washers. Have you torn it down and verified yet?
it may have been took apart thisafternoon not sure What torque would you put em at?
