standard size bhaf filter installed on my 04. very tight fit, but it's in there...
Are my pumpkin temps too hot??
New Box Questions
well... i gave installing a bhaf filter into my 04, and when i first got the filter, i thought it would never fit, but after looking and test fitting for a few minutes [like 30-45min:rolleyes:] i decided to start trimming. i removed the battery on the pass side and the battery tray to see things better [didn't take pictures of that though]. i trimmed out the plastic inner panel behind the battery tray that has the molded in part for the factory air box snorkle. i also trimmed off the one mounting ear off the battery tray that the factory airbox mounts to [the one closer to the fender]. after reassambling everything again, i dry fitted the filter and it seemed to fit ok. the bottom of the filter is resting on the pass. side headlight adjusting device. it clears the alternator by about ±1/2" it is close, but shaking the filter around by hand and it doesn't touch it. i made a mounting strap for the filter from some 1/16" lexan with some foam tape on it that i had at home. and it is screwed into the battery tray and it holds the filter pretty well.
the turbo is a little bit louder than the factory airbox with a 4" hole in the bottom, and seat of the pants performance feels better. i wasn't expecting any performance gains [i wanted turbo song :D] but it does feel like it's got some more pep. down low it spools a bit quicker and gets to max boost quicker.
as for egt, hard to say. last time i made a run watching the pyro was when i first installed it, and it was a cold wet rainy day [5-6°C] and i could hit 1100°f. today i went and did the same pull i did last time, but todays temps are much hotter[28°C and humid] and i almost saw 1200°f near the redline. but crusing speeds egt looks to be a bit lower than with the stock air box.
i have pictures, but they are a little slow at being uploaded to my webshots gallery. i'll post a link when they are up.
***edit***
pictures here
the steel connecting pipe is a short radius 4" exhaust elbow eith 4"OD on both ends.
Congratulations Nick on taking the lead in the BHAF game. I have wanted to do it, but have not taken the time to put toward it.
Blake Malkamaki
(the other Finn on here)
Hey Nick, how did the passenger side battery tray come out? I was going to remove mine a couple weeks ago for some other work but stopped when I realized you need to take out the wheel well liner to get at the lower bolts for the tray. Is that true, or was I seeing things wrong?
there is the 4 bolts on top that you can see, and then there is 2 more under where the wheel well liner covers. a few of the wheel well liner screws are attached to the battery tray. i didn't take the liner out, just took all the screws out of it and let it sit on the tire.
Originally posted by Double J
What is the part number on that filter?
Thanks
the filter i used was a napa one, which is #2790 at napa.
other cross ref. numbers
wix 42790
fleetguard AH19037
donaldson B105006
baldwin PA2820
